New to Cricut
DCRamosDCRamos Member Posts: 1
What alternative brands or products can be used with the Cricut.
I want to create an iron-on and the the Cricut red sparkle and or foil is not available. I was wondering if other brands can be substituted?
Thanks!
    Cricut is not supported on this forum but I don't see why you should be limited in materials that you can cut on the Cricut.  Other brands should work just as well.  I use a cricut mat on my KNK Force and any material up to 400 gsm - I'm guessing you would be limited in the heavyness of material but not its type.  There are a couple of cricut users here so they will be able to advise you more ably and put you in touch with the correct forums.
