New to Cricut maker, id like to cut paper stencil design cutouts , deck style, with card stock
magicmarcmagicmarc Member Posts: 4
hi, i just got a maker, and i got it because i want to cut out stencils, onto paper card stock, but id like the cricut to make several 'per page' of card stock, about the size of a playing card, but with the design cutout on it, and the rounded 4 corners... so id like to make blanks, just the card with rounded corners, and another one with the same but with the stencil design cutouts in them...
like this, does anyone have some good steps, pointers to give a newbie on how to do this?
  • magicmarcmagicmarc Member Posts: 4
    and of course the same thing, with just the rounded corner 'card's with no stencil design cutouts..., thanks experts!
    @magicmarc - welcome to the Make The Cut! software forum, where we assist users of the software Make The Cut! (MTC). MTC is not compatible with your cutter. We can point you to a MTC user manual but if you are not using MTC then it's likely not going to help you. You need to learn either the software that is compatible with your cutter, or purchase software like MTC (I would actually recommend SCAL instead) or use freebie stuff like Inkscape.
    Did you get this resolved or do you need help with the design?
    HI d-LITE, i was told this isnt for cricut folks, this is something else.. i did manage to 'get a cut of the design made' but i dont know the design software well enough to make the rounded corners, etc... the details i like, ya know, are you good with deisgn maker?
    edited February 7
    No I don't know design maker.  The question I would ask is can you import svg or similar.  If you can and you you give me the parameters of the rounded rectangles you want then I can put a set up for you in various sizes and with various corner curves.  Or let me know what types of files you can import I might be able to assist.  Do you have basic shapes - you might fin that it has rounded corner rectangles.
  • Crazy_Mr_ZingCrazy_Mr_Zing Member Posts: 3,452
    Youtube and google is a good way to find out how things are done in Design space
    I found this page and I think one phrase on it says it all
    "Here’s the thing, Cricut Design Space is not really really meant for you to design complex things from scratch. "
    https://daydreamintoreality.com/rounded-corners-cricut-design-space/
    Cricut design space allows import of svg files this provides the option of designing in other far more functional design software and then importing to design space
    Inkscape (Freeware) would be one such software you would find many pages / video showing this
    https://www.leapoffaithcrafting.com/inkscape-cricut-design-space-tutorial/
    Adobe Illustrator and Corel Draw would be other option each may require certain setting to make the svg export compatible with design space . I suspect google would help you here as well
    Using software actually intended for electronic cutter can have advantages
    for example
    Make the Cut or Sure Cuts a Lot
    Neither will cutter directly to the Cricut as its manufacturer took action to prevent that
    But each can be used to create svg the can be imported to design space once again there may be certain adjustments required . I would think there would be information around the web about this
    Sure Cuts a Lot  does has a export svg for design space option
    Another good source of help would be Facebook Groups for both design space and also the Maker
    There are many here are 2
    https://www.facebook.com/groups/cricutmaker/
    https://www.facebook.com/groups/DesignSpaceFans/
