Registration code
I am trying to register make the cut on my new computer. When the screen comes up for entering the registration code I have used copy and paste to input the number. The accept button does not change so I cannot get it to accept. I also tried to enter manually. Does anyone know what the problem is?
Sheila owns a Zing and Cameo
    edited December 2018
    Are you entering a Registration code or Pin Number ?
    The accept button remaining grey out usually means the code does not match the requirements for a valid code
    ensure you are not including a blank space when you copy/paste the code
    Registration code for make the cut begin with MTC follow by maybe about 30 characters (from memory)
    are you on a Windows machine Or Mac
  • ssmithssmith Member Posts: 606
    Thank you! I was entering the registration code for PCS instead of MTC. I requested registration numbers for both programs and received the same number in both responses. It didn't click with me that the prefix would be different. Luckily I found the MTC registration from my original order as my email had changed. Now to get my computer to recognize my cutter.
