setting to cut plastic help please
bubblestickerbubblesticker Member Posts: 6
I have an older zing. works fine for what I do. I have cut simple decals for years
I needs to try cutting 0.015 inch clear plastic
any advise on what setting i should use? do i need to cut more than once? the force is set at 73 and has been for years? should i change that?
do I need to adjust the depth of the blade?
thanks in advance
Marc
