Cameo Silhouette cutting plastic?
jschmidtjschmidt Member Posts: 75
I have a piece of plastic that I need to cut into which is about 1mm thick.  I've tried the cutter blade on 10 and put it at a speed of 1.  It doesn't go all the way through unfortunately.  Are there any other options for me?  Is there a bigger blade available or a tip/trick to try to do what I want it to do?  Thanks in advanced!
