Printer margins seem to cover registration marks
I am not explaining myself very well but I have a page and I am doing print and cut. I center the items on the page and it looks like this (the registration marks are inside the margins):
Here is what it prints and puts in the print preview:
It is fine in this case because I caught it before I printed 50 out and shifted things. But it has happened before that I don't catch it.
None of my other applications seem to have this problem. I just did a test with Word and the margins are right where I expect them to be.
Does anyone know what causes this or how to fix it?
I just added another line of circles to the left of the first column and the print preview showed more than I expected. So I think the whole printing has just shifted left by maybe .25".
Connie
Gallery ID: 20273
    Just wondering if you have your printer set right for the margins or no margins.  The preset is different in different programs and it all hangs on what margins you have set for Word and what margins you have set when sending direct to the printer from MTC.  MTC doesn't contain margins directly it just shows the print preview page.
    Also looking at you MTC page I would move everything over to the left a bit more.
    You pattern doesn't seem to be centred on the page
    I think a approximated centre would be where the red cross is
    and the blue arrow the centre of the page
    as a Diana suggest move over to the left
    But I think would may be pushing your luck a little prints are usually not so accurate at placement on the page some are better than others) if you reg marks are very close to the printable area edge you may find the cut of on some pages
    The other thing you could try is reducing the gap between the circles some the overall size of the pattern fit the pages better
    But before that  I not sure what cutter you using but small repetitive print and cut often drift out of alignment as any minute slip multiples but the end of the task
    I would suggest adding some bleed to overcome the slightness misalignment
    as for your question
    I not sure why the print area indication on the mat does not agree with the print preview
  • walshsurveywalshsurvey Member Posts: 553
    I found the MTC margin setting. It is in  print options under the file menu and I must have clicked it by mistake one time. It is the 3rd item down and it is called "Do Not Offset Printer Margins". I had it checked, I unchecked it and everything went back to normal. Thank you for your responses.
    Connie
    Gallery ID: 20273
    How about that I have never notice that setting ?
