Looking for Explosion Box with Cake with Tea Light Template
CharoCharo Member Posts: 732
Does anyone have a file to share or know where to buy one that doesn't cost a fortune?  I am looking for a way to attach a three-layer cake so the battery in the tea light can be replaced.  Found one but I don't care to pay $9 for the pattern, when all I need is the cake itself.  Willing to pay, just not $9.
    Can you provide the link to the example
    So I can get and idea what your looking for
    Ok I think i know what that are now are did some googleing
    Though a didn't file a file I found a assembly tutorial that gives quite a clear idea one method  construction
    I think you could use templatemaker.nl as they appear to be very much like round boxes
    Using the round box template maker
    discard the lid and add the glue tabs along the bottom
    This may look a little odd if you haven't use this template before
    the rectangular shape surrounding the circles is actually a jig to aid assembly
    the only puzzle is how to enable switching the candle on ?
    @Crazy_Mr_Zing what a good idea!  I love template maker and never thought of it.  Yep I've watched a ton of videos on how to put the cake together.  As you say the problem is turning the tea light on.  One of the videos showed the top two layers attached to the solid bottom layer with a paper onto which a magnet was attached.  So that's my idea right now.  My project gets even more complicated because I want to use a tea light which runs for six hours after it is turned on, then is off for 18 hours, so one doesn't have to keep taking the cake apart to turn it on and off.  But these candles do not have a flat top and they are significantly higher than the old flat-topped tea lights.  I don't know if I can do this but am giving it a try.  I want a stunning box for a lady's 90th birthday.  If one reached 90 with all their marbles it is something to really celebrate these days. Thanks so much Mr. Z.  I am grateful you are still in the forum.
  • craftyladycraftylady Member Posts: 192
    https://www.jamieandjenn.com/birthday/jld-3-tier-birthday-cake-tealight?rq=birthday cake. This one is really cute and super easy to put together. The light sits right inside so it can be easily turned on and off. Good luck!
    I gave a friend a mini pumpkin with a tealight in it a couple of years ago. We left the tealight on to see how long it would last....it lasted long past Christmas. Just a FYI.
    edited October 2018
    @ Charo   What are dimension of the body of your candle
    I see some the have a melted cable look top that might make think a little difficult
    first though was if the cover could be removes but i guess the flame is attached ?
    SO then thought made it possible to swap the melted look cover with a regular shape candle
    I forgot to mention templatemaker has a maker for and explosion box too
    edited October 2018
    Me Again LOL
    I just thought of another method using the cylinder with mitres ends maker
    just set the angle to 0
    I played a little not might need some tweaking
    ---- Just realised there a flaw in my design I didn't allow for the thickness of the material
    I hate doling round boxes.  I would use hexagonal or octagonal as they are easier to assemble.  Say three sizes stacked and decorated up with filligree openings so that the candle can shine through and ribbon or some other form of decoration stuck on.  You could make a tiered wedding cake style (squares) stacked.  Susan Robot does some nice round boxes and a tutorial on how to assemble.
    Thanks so much to everyone for all the help.  I wish I had waited another day to incorporate all the great ideas but as usual I am in a tearing hurry to get it done in time.  That pattern link sent by @craftylady had a grand idea to just sit the candle on top.  That could easily be attached with a little magnet.  I must say @Di-lite I didn't have much fun with the round boxes either, even though templatemaker's pattern was perfect.  It just isn't easy to keep the boxes round at the join, especially when adding another decorative paper.  If I hadn't already glued the bottom round on I'd make a different shape.
    But the magnet idea worked, although the repositional glue dots aren't holding.  Maybe I don't need them.  Here's what it looks like now....will send a completed photo when finished.  @Crazy_Mr_Zing Surprisingly I was able to trim off cardstock around wavy candle top with scissors.  Will cover up raw edge with some sort of bling.
    P. S.  I loved PaperChaser's idea to fold the base corner pieces inside to reinforce sides.  No need for score lines that way and it eliminates the need to adding a decorative piece if one doesn't have double-sides paper, which I almost never have.
    This looks Great
    It would have never occurs to me to use the glue tabs as a feature
    That looks great - I like the stairs hiding in the back there.  LOL
    @Di-lite oh that stairs!  That is from the Townhouse Dollhouse from Kineticpaper I made.  Months after it was done I discovered I had put the hand rails on backwards.  I am getting really good at removing glued parts.  And @Crazy_Mr_Zing had to laugh that you said you didn't allow for the thickness of the paper.  I did exactly the same thing when making decorative strips to cover cake forms.  Everything looks so good on the computer until one applies it all to 3d paper.
