uploading an svg/pdf file
Hi,
I'm trying to upload a file but instead of the expected item I only get a grid of blue outlined boxes with a few filled in boxes in grey. What's going on? I tried a different one earlier and it worked fine.
Thanks
Gina
  • Liz_ALiz_A Member Posts: 10,133
    @Gina13 - what software are you using, how did you make the file, and when you say "trying to upload a file" what do you mean...upload to a webpage somewhere, upload to the MTC Gallery or open the file in Make The Cut!.
  • Gina13Gina13 Member Posts: 2
    I was trying to open an svg file in Make the Cut. I bought it on Etsy and wanted to use it in MTC to cut out some flowers. I bought some others on Etsy as well, and they work fine. My suspicion is the file is too big - over 4 MB compared to the 30 or so KB of the ones that work. Could that be the problem?
  • Crazy_Mr_ZingCrazy_Mr_Zing Member Posts: 3,414
    edited August 2018
    I assume your using the svg or pdf import function in MTC ?
    It difficult to say what it issue is
    Was the file sold as a file for cutting on a machine
    If it was intended for print and cutting by hand
    I would suggest the file was created in a Vector Program like Corel or Adobe Illustrator and contains allsorts of masking layers and groupings which can cause issues when you attempt to import it to MTC
    Good point Brenda
    Pdf's come in Vector format and Raster and sometime include both
    PDFs can also just be a picture image with no raster or vector information at all. Totally depends on how the pdf was generated.
