Random cuts throughout my image.
My silhouette cameo all the sudden starting cutting random cuts throughout my image im trying to cut. Please help me fix this. im scrapping so much vinyl trying to figure this out.
  • GabeGabe Moderator Posts: 4,535
    Stop using vinyl while you figure it out.  Use inexpensive paper instead.
    edited August 2018
    You need to provide some information back without where really just guessing
    Are you using Make the cut software or silhouette studio ?
    If you are using Make the Cut is it  registered as the demo version will cut slashes across you pattern
    Which model cameo ?
    Are they random cuts or are the paths between the actual cuts being cut
    eg the blade is not lifting between each object
    or are the total random with not relation to the pattern being cut
    Possible cause of then could be machine failure or communication issue
  • Liz_ALiz_A Member Posts: 10,195
    @jkward73 - welcome to the Make The Cut! forum where we support the software Make The Cut! and its supported cutters. MTC does not support any of the newer (last 3 years) Silhouette cutters, so I am going to assume you are using one of those and the Silhouette Design software. You will likely need to find a support form specifically for SD or contact the Silhouette America support team. If you are using MTC, then it sounds like you may need to re-register your software.
