I am trying to get the horizontal lines to weld only inside the left piece of the “G.” I want the rest to disappear. I’ve tried Boolean every which way and I’m not gettin it this time. Help?
I don't see an image is the code for the page either sometimes the image will fail uploading usually a message will display but it easy to miss it was it bmp, jpg or png ?
Boolean join will only work with 2 object and those also need to be closed paths
Thanks! Through much manipulation I got it. I had to do a shadow of the letter and work with that and it Boolean joined. Sometimes, you gotta strip it down and dress it back up!
