@allthingsknotical - Welcome to the Make The Cut! software forum. We support users who are using the software Make The Cut! with their cutters.
You'll have to isolate the anchor from the other pieces that are connected. Don't know how to do that in Silhouette Studio, but look for a tool that looks like a pencil and draw lines where needed to isolate the anchor.
I think the anchor outline is a open path meaning it has one or more breaks in it
open path can not contain fill
once you make the anchor outline a closed path you should the be able to subtract the circle and the diamond and then be able to apply fill to just the anchor shape itself
Once the anchor is a closed path you should be able to subtract the circle and the diamond from the anchor shape and then add fill.
