wysiwyg in black cat cougar misses the image by 1/4 inch
MonetMonet Member Posts: 4
for some reason when i use the wysiwyg with black cat cougar cutter, it no longer lines up around the image.  it is off by about 1/4 inch!  below and to the right of the image.  it cuts with print and cut just fine. perfectly. so i don't want to have to mess with the tools to adjust the x and y factors...
does anyone out there know why it is doing this??  and how to fix it? easily???
  • BarbaraBarbara Member Posts: 491
    Try a factory reset.
    Did it once line up perfectly in wysiwyg
    since then has anything changed ?? new computer maybe ??
    does it do the same with other files ?
  • MeFlickMeFlick Member Posts: 9,188
    Are you using the black cat plugin or the knk Maxx ( not the Maxx Air) plug-in? It’s been a longtime, but as I recall one of the issues was that the black cat plugin you had to set the blade in and over in WYSIWYG mode. You didn’t when using the KNK plugin. Unfortunately, Andy never updated the BC plugin to fix that which is why most people learned to use the KNK Maxx plugin with the BC and Silver Bullet cutters.
