Signcut pro tx issues
mariesvinylsmariesvinyls Member Posts: 3
Hi all I’m a newbie at vinyl cutting I have a pixmax cutter I use signcut pro
When I’m trying to do wall art the fancy joined up writing (great vibes ) where the writing joins up the lines that overlap each other have the lines running through so when the cut is made it’s separating the writing .what am I doing wrong or signcut pro crap software to use can upload a pic if necessary thanks also there’s nothing on signcut to edit the lines out of the tx
    @mariesvinyls - Welcome to the Make The Cut! software forum, where we support the software Make The Cut! and its supported cutters. We don't directly support your software Signcut Pro.
    Please do a screen shot and post that as your description of your problem is not very clear. What is "tx"?
    Yes a picture often helps
    I'm thinking your wanting to create one shape from overlapped letters
    In Make the Cut we would use the weld function
    I could be incorrect but after a quick look signcut pro appear to more a cutter interface than a design software
    if so it may not include those functions
    I'm thinking you maybe able to design in another vector software and import the created file to signcut Inkscape would be a no cost option
    other non free options would be  Adobe illustrator  or Corel draw
  • mariesvinylsmariesvinyls Member Posts: 3
    Thanks I use Inkscape for designs, pics etc but on signcut there’s a text option I use that for text as I haven’t figured out how to open the text created in Inkscape with signcut il upload a pic
  • MeFlickMeFlick Member Posts: 9,199
    One note about text created in Inkscape - it remains text and not a "vector object" until you convert it to an object.  In order for a cutting program to recognize it as an object to be cut, you must convert it to the object in Inkscape before saving the file or exporting it out.
    Thanks il av to try Inkscape can be very tricky at times
  • GabeGabe Moderator Posts: 4,543
    edited March 2018
    My suggestion would be to buy Make-The-Cut and use that to create and edit vector cut files.  I've never tried it, but I've heard that Sure Cuts a Lot is a pretty good vector design program and it has a few features that MTC is lacking.
