Boolean Join with Texture [Resolved]
CharoCharo Member Posts: 740
edited April 2018 in Resolved Issues
I have tried everything I can remember and I know I am forgetting something because I have done this before.  The textured shape won't completely fill the green shape.  Have rotated, tried join, tried separating layers and moving them up and down.  What am I forgetting??
    I really getting what your meaning
    this is what i see when i open you file
    is it the pillars that have the issue ?
    what method are you using to apply the texture ?
  • CharoCharo Member Posts: 740
    Oh no I attached wrong file!
    @Crazy_Mr_Zing ; here is correct file.
    I even remembered to uncheck auto thing in boulean join; still won't fill entire shape.
    edited March 2018
    First you may wish to perform a break on each shape and remove these  small shapes i assume they are not wanted
    also maybe increase the size of the textured shape so the part is covered
    Now to fill the green shape with the texture of the other
    the textured shape need to be above the green > which it is
    Select both shape do a join and then break
    (usually break does but if something strange happens try split)
    As for you first file I not sure it those white part on the pillars were intended
    but it figured out a fix  by altering the texture offset
    Oh @Crazy_Mr_Zing.  How simple this was.  I tried everything except the break after joining.  I was so certain the boulean join was supposed to work.
    And you even fixed a file I gave up on a long time ago.
    Now just how DO you remember all this?  Do you make something every day, do you dream MTC in your sleep like Di-lite does?  Do you have notes everywhere??
    Well thank you is all I can say.  I am grateful you are still around on MTC.
    I remember MTC functions quite well for the most part
    specially this join break one because it always seemed a little like wizardry
    I also spent a great deal of time figuring out how to get around the limitations
    MTC has which it has a few relation to textures and how they are positioned
    if computer says no well I bash away till I find a way sometime it can take a few bouts .
    Apart for that helping others with their issue help me not to forget and often i find a new ways of doing things
    @Crazy_Mr_Zing ; That is a good description of the way the join and break works....wizardry.  Maybe that will help me remember it.
