I’m retiring in 2 months! My posts are not going through. I upgraded MTC to the latest version. What is the best heat vinyl for easy weeding?
I haven’t crafted in 5 years.
So I don’t know what happened to the rest of my post!!! I finally upgraded my MTC software to the latest version. I haven’t crafted in 5 years, so it’s going to be like learning the program all over.
What is the easiest heat vinyl for weeding?
Thanks Rhoda
Hope this goes through
@Rhoda Jayne - I just did a big project with a lot of small text. I was very pleasantly surprised at how very well Siser HTV performed....of all the text, I only had the dot on a lower case "i" move. Everything else was perfect! Trick is to reduce the speed of your cutter.
Hi, what do you mean your posts are messed up? Are you trying to load a picture or a file? If so you should be able to drag and drop in your post. If it is something else can you explain a little more - thank you.
Thanks Rhoda
