Cricut Adhesive Foil and my KNK Zing :(
misscristiemisscristie Member Posts: 3
Hey everybody!!  I had some life changes over the past couple of years and didn't have the mental/emotional/creative bandwidth to do the things that bring me peace, but 2 moves later I'm trying to use my Zing for the first time in what feels like FOREVER.
I bought some sheets of the Cricut adhesive foil to create a super girly house number for my Victorian beauty.  I wasted all of my vinyl trying to get the settings back to where they should be and I really don't want to waste all of this too.  I'm using the blue blade.  Pressure of 90 still didn't cut all the way through, so I upped it to 100.  In some places, it still didn't cut through the foil.  In other places, it cut clean through the backing paper.  There is ZERO happy medium here.  I can't find any place where it didn't do one or the other - no clean cuts.  AT ALL.
Is my blade shot?  I'm fairly certain it was new, but could be wrong - It's been a minute.  Anyone have any experience with this material?  Any help is greatly appreciated!
--Cristie
    I'm not familiar with Cricut Adhesive foil is it like vinyl or much thinner and actually like foil?
    The blue blade is usually used with thicker material very heavy card - chipboard
    The Red Blade is what is usually what would be used for vinyl and thinner paper based materials
    When cutting a material that your unsure of cut setting is best to cut small test shapes similar to that of your project then once you successfully cut then cut the full project
    Is you blade shot can you see if the tip is chipped
    I guess one way of testing this would be trying to cut some other materials
    You don't mention that you set the blade exposure (length of blade ) to match the material or the height you mounting the blade holder
    this can effect the cutting result greatly
    As vinyl if very thin only tiny amount of blade should be exposed
    this vide show a technique of determining blade exposure
    I wondering if it maybe worth wide cutting some less expensive materials why you get back up to speed with your cutter
    edited February 2018
    Foil? Why are you cutting something thin with the blue blade? You should be using the red blade. If it is not cutting, though I would expect it would be chipped - look at it under a magnifying glass. I do not know what blade holder you are using, but it sounds like you have the pressure way too high. If you are using the knk holder - did you test the blade depth - for foil only a little blade should peek out and when you put the blade holder into the blade carriage, are you using the proper number of post-its above the material loaded mat?
    1.  Your test shape should have been about 0.3" x 0.3" in size (I use a donut shape) so that you could do 20 tests and waste less than a half inch by 10 inch strip of material. And that's in the worst case. I normally have the setting nailed in 3 test cuts.
    2. You should ALWAYS use the red blade with any thin material.  The blue blade is only for thick materials like craft foam, balsa wood, cookie dough, etc.
    3. You're in luck!  After a KNK owner posted some amazing photos of Cricut adhesive foil designs she cut for the front of greeting cards, I picked some up the other day.  I will gladly test cut it for you and give you some suggested cut settings for your first TEST cut.  I have a flow chart that will then guide you on how to adjust your settings or, if a flow chart isn't something you can follow, then you can post photos of your small test cut along with a photo and I'll happily advise you on how to change your settings.   Here's the link to the flow chart:
    http://www.iloveknk.com/2015/06/test-cutting-materials-a-troubleshooting-flow-chart/
  • misscristiemisscristie Member Posts: 3
    I actually meant RED blade.  My little glass box with my blades in it was in front of me and I could see the blue blade.  ADHD + visual of blue blade = crossed wires.  The blade is exposed enough to cut through the material.  I will check for chips,  I already ordered some new blades just in case.
    Sandy, thank you for the flowchart!!  I had actually done several small test cuts after I realized that it wasn't going to cut like vinyl and thought I had it pretty close when I cut the number which is why I was baffled that it didn't cut through in some spots and cut clean through the backing in the rest.
    I appreciate everyone's advice.  Sorry for being a ditz and putting the wrong blade!!
    Did you get it to work now?
    My new blades came yesterday.  I have it on my agenda to try again tonight.  Will let you know the results :)
