Help! My black cat cougar 2012 stopped cutting, its acts like its not receiving the cut file. Was working just the week before as I cut some Alice in Wonderland stencils, some with some great detail in them. I went to use it the other day and nothing. I know the BR is set at 38400 on software and machine. I feel it has something windows 10, but I was using Window 10 during my last cut, so I am not sure. I have also tried using the laptop vs the desktop and get the same response ( both are using Windows 10, I called to see about getting it serviced but was told that most likely not repairable, its just hard for me to believe it was working great then just stopped.
0 ·
Meanwhile, I don't like seeing you give up on your BC. Who is your original dealer? That's normally where one would go for assistance.
Sometime windows can block driver installs
with the ftdi exe file you may need to right click on the file and select run as
administrator
I thinking it this is a result of the latest huge windows update other blackcat users would also be having issues is there any mention on their forums ?
I don't much about the intricacies of the blackcat ? would it worth trying the SCAL just to see if it can communicate with the cutter ?
New Year.
Or from before all that drama
If the latter I read somewhere he maybe connected with this webpage in the UK
https://www.robocutters.co.uk/
(1) Serial cable that came with your cutter connects to the cutter.
(2) The 9 pin end of the RS232 converter connects to the end of the serial cable.
(3) Then the USB end of the converter hooks to the computer.
Is that how you connected it? Lots of owners will NOT use their original serial cable because they assume the converter can be used alone. But it doesn't work that way.
