Angels
Di-liteDi-lite Member Posts: 3,467
Hi peeps, I done two angel things for Christmas - one is a tree topper which needs careful assembly to get the arms correctly positions.  I've done three sizes of this one.  the other one is a table decoration of a 3D angle.  Again tricky to glue together but looks good when done.  You will find them under Festive/angel ...  Before making either up in good material I suggest you do a proto type and check that it performs to your taste.  You may need to make some miner alterations.
