JGW Santa's Repose Armchair - Chair Label... I vamooshed it :-( [Resolved]
Hi all, I have the JGW Santa's Repose Armchair template but somehow I have deleted/removed the label that hangs over the back of the chair. I always make a copy and work from that but in this instance I appear to have overwritten the original.
This is the label, if I have to I'll make it in Affinity Designer (AD) and export as an SVG but thought I would see if anyone would be so kind as to send me just the label as an SVG first as it would make things a lot easier. I have the outer and inner shape its just the text, hearts, swirls and branch I need.
I'll doodle away in AD in the meantime and if I get acceptably close I'll let you know.
If you purchased the file from SVG Attic, you could contact customer service and explain your situation. They probably would be able to help you. http://www.svgattic.com
no contact from svgattic nor the original author of the template but I have created a facsimile of the elements i wanted, so as far as i'm concerned this is now resolved.
