knk orbit mats
rituritu Member Posts: 6
hi i am in india and knk mats are not availible here where as silloutte and cricut mats are availible . can i use any of these mats in orbit . otherwise what do i do
  • MeFlickMeFlick Member Posts: 9,124
    Yes, in general - you can use other cutting machines mats in other cutters as long as they fit.  On the orbit you can adjust the position of your Obit's pinch wheels like other KNK cutters to accept smaller mats.  Therefore could use these mats but would have a slightly smaller cutting range since those mats are only 12" wide and the Orbit cutters are 15" and 24" cutters.  You just need to make sure that the pinch wheels are properly aligned with the tab/grit shaft locations on the bars so you get the correct pressure on the mat.
    Bumping since this is a duplicate thread to another and this one has an answer provided for the OP.
  • Crazy_Mr_ZingCrazy_Mr_Zing Member Posts: 3,262
    Not sure how current this info is
