Help! Sticking to the mat
ginamackginamack Member Posts: 1
Hi could anyone help me as my cuts are sticking to the mat, I'm literally having to scrape them off :(
  • Crazy_Mr_ZingCrazy_Mr_Zing Member Posts: 3,224
    edited September 2017
    What machine are use using ?
    Positioning your material so the rollers roll over can lead to the material sticking down.
    The stickiness required varies depending on the material you're cutting.
    It takes a little practice to be able to judge.
    It's also important the adhesive is applied evenly. If it is uneven it can lead to cutting issues.
    A method of reducing the stickiness of your mat is to lay a old t-shirt on it and roll it down with a brayer or a rolling pin then peel off the shirt.
    The idea is to transfer lint off the shirt which makes the mat less sticky.
    When a mat begins to become not sticky enough rinsing under tap water can rejuvenate the sticky.
    Try some undue.
