Dreaming Tree files [Resolved]
Mrsstack79Mrsstack79 Member Posts: 9
edited September 2017 in Resolved Issues
Whenever I open up one of the Dreaming Tree files in MTC the SVGs are importing in smaller then they should.  I'm running the latest update of MTC so I can't figure out why this is.  Can anyone help?
Dawn
    I might be the Dreaming Tree files are a different DPI (dot per inch)
    I think the only workaround would be to calculate the percentage difference and them resize the pattern in MTC
    mtc accepts percentages in the dimension  boxes
    @Mrsstack79 - yes known issue. TO fix:
    - click in either the HEIGHT or WIDTH value, making sure that everything is selected, and that you have the lock symbol toggled, ie, it is gold, then type 125% and press Enter
    Problem solved. The images are 72 dpi and MTC uses 90 dpi, so they are smaller.
    You can also check the values of a single shape by looking at the menu file provided. You can then resize individuals by typing EITHER the height or width, and pressing Enter. Remember the lock symbol MUST be toggled, ie GOLD and locked.
  • PennyPenny Member Posts: 2,173
    This is what I do with their files. It shows on their PDF the size it should be - I change the width to correct the size. Make sure you lock is on where changing the size.
  • Mrsstack79Mrsstack79 Member Posts: 9
    Thanks for your help.
