Help with Node Editing [Resolved]
Sheri_in_TXSheri_in_TX Member Posts: 559
edited August 2017 in Resolved Issues
I haven't been here in a really long time.  Guess I've been able to do everything I need to do without a problem.  Now, I'm having an issue in node editing and I'm sure it's been covered somewhere, but I can't find it.  Can someone either answer my question or point me to the webinars/tutorials where I can find an answer?
I have a single shape (small cursive letter "a") where the top of the loop does not connect.  Right now they overlap.  It will not weld together.  I'm sure there is a way to join the overlap.  Can someone help?
I'll take a screenshot and attach it to the post.
Thanks! Sheri Lynx devours Cricut. Film at 11:00. (The opinions expressed herein are mine alone and are not endorsed by or supported by the owners, authors or editors of this board. My opinion has not been coerced, bought or paid for by any person(s) or entity(ies). In other words, you got a problem with something I say, take it up with me, no one else!)
    edited August 2017
    what font is that?
    I recall this issue being covered but can't remember where
    maybe this video will give you some pointer on node editing
    Make the Cut Software -Node Surgery Tutorial
  • Sheri_in_TXSheri_in_TX Member Posts: 559
    Thank you!  The font is called akaDora.  I'll watch this and I'm sure it will answer my questions.  I really appreciate the help.
    PERFECT!!!  Thanks Mr. Zing!
    Now If I recall correctly if the issue is with overlapping sections of the same letter you edit the nodes
    But to overcome this issue which overlapping parts on another letter you can select split by glyphs in the text windows then they should weld properly
  • jesprattjespratt Member Posts: 59
    Another way to fix it is to use the inverse eraser to fill in the gap.
