Alignment issues for cutting out sparkly paper
jschmidtjschmidt Member Posts: 66
I have a cameo silhouette and have been trying to cut out a printed design on a sparkly type of inkjet paper.  It cuts, but it cuts slightly cockeyed and about a half inch off, which ruins the entire project.  Are there any tips or tricks I can try to get this to work properly?  Here is a picture of it below.
    In general when skewing occurs, it's due to a material being cut faster or more deeply than the blade or the cutter can handle. Thus, try using a slower speed and possibly two passes at a lower force setting.
  • jschmidtjschmidt Member Posts: 66
    Thank you for the response!  One thing I think I should mention also, is that when the unit makes a pass over the square registration mark, it makes a bit different of a sound than usual, which leads me to believe it isn't the cutting speed or thickness.
  • gll5613gll5613 Member Posts: 39
    The sparkly paper might be causing inaccurate detection of the registration marks. If you have white non-reflective labels, try adhering them to the sparkly paper in the areas where the registration marks will print.
