Dear Crafters, Any ideas for a DIY equivalent of Thermoweb's Deco Foil Gel?
hwganghwgang Member Posts: 2,805
I saw a Jennifer McGuire video using it and the results were amazing. I'd love to try it, but of course, it's out of stock everywhere.  Then it has to be mail-ordered and there's shipping costs when you just want one, small thing. I'm feeling curmudgeonly about the whole thing today.  :-P
Is it just an adhesive that can take the heat and has the right consistency?
Has anyone played with it? Thanks.
Lynne
  • Liz_ALiz_A Member Posts: 9,900
    @hwgang - how were you wanting to use this? With a stencil? Foil will stick to glue - this web page might help.
    http://www.crafttestdummies.com/six-ways-add-foil-crafting-projects-without-machine/
  • jewelleenjewelleen Member Posts: 11
    @hwgang, I saw her video as well and tried the technique using Dervan Matisse Gel Medium Glossy, which I had on hand. I was happy with my first attempt. Worked very well with a stencil, haven't tried a stamp yet.
    I would experiment with any brand gel medium you have on hand.
  • hwganghwgang Member Posts: 2,805
    The look I am trying to imitate was done with a stencil and then a laminator. It give one foiling with dimension!
    @jewelleen I don't have any gel medium I have on hand, but it will certainly be easier and less expensive to get some of that.
    @Liz_A Thank you for the reference. Off to look!
    Lynne
  • melmomelmo Member Posts: 102
    I just tried using a very thick fabric glue with a stencil. I let it dry completely then ran it through the laminator. I worked exactly as the decofoil transfer gel as far as I could tell. The fabric glue I used was Aleene's Fabric Fusion but I'm sure any thick heavy bodied glue will work.
    I read something over the weekend that I have yet to try. Use an embossing ink like VersaMark, add a clear embossing powder to it, heat set it then apply your foil and run through laminator. VersaMark can be used on stamps very easily.
