Need help!!! Resolved!!
Di-liteDi-lite Member Posts: 3,330
edited June 2017 in Resolved Issues
Hi Folks, I've designed a vase type construction - the problem is how to stick the top part to the bottom.  I've tried thick glue but it leaks through the join.  I thought of using tabs but that is extremely difficult for my fingers - any other ideas would be appreciated.  I'm putting up a file for you to play with and see if you can suggest a resolution.  Here's a photo of what I am trying to achieve.  The left one I set tabs but not the right length!!  The right one I tried gel - it works after a fashion - as I have a lot more designs in this group it would be nice if a solution could be found - I'm at a loss.
Post edited by Di-lite on
