Setting up for using a 24 inch cutter?
Hi everybody I did a search but nothing obvious? I have a Liyu 630e cutter (a UK version of the US cutter basically) I have the cutter set up but cannot see how to adjust for cutting larger than a 12x24 inch mat?
I use sign cut pro at the moment and only came across this software as I came across a cheap cricut and was looking at software but it looks a better option for my big cutter if I can cut full size of 630 wide up to 50m long?
Many thanks in advance.
