Creating a stencil
minicuriosminicurios Member Posts: 16
edited April 2017 in General
Hi Everyone,
After some advice please... I have pixel traced a design but it appears that I may have too many nodes. I have tried auto simplifying the file many times and I am down to 3500 nodes approx. What is the maximum amount of nodes a file should contian? My SNC can't open the design as it is too "complicated>"
What am I doing wrong?  I will continue on with my research and if anyone can direct me to a good youtube video on stencil making it would be much appreciated.
Thanks
Angie
Post edited by minicurios on
  • SandyMcCSandyMcC Member Posts: 7,304
    Try selecting your shapes and then clicking on the wrench icon and selecting Flatten Paths. See if that makes a difference with your import.
    Regarding stencil making, if you are referring to bridging internal paths to the outside, then watch this one:
    I think i may be a little difficult to pin point where thing went a little of track
    I think it better if you attach the MTC file as sometimes it provide a few more options for us to work back from
    is this the sort of thing you looking for
    if saw a few issues with you file
    the gaps between the rocks are separate to the frame to the pattern be cut apart
    and you rock are over lapping in places
    This is how I fix you file up a little
    -Do a layer
    -Move the rock pattern to a new layer
    -With only the rock pattern selected create a inset shadow I use -0.005 but you could experiment a little
    - hide the layer the contain original rock pattern
    - select the both the rock pattern and the rectangle and do a join
    Now because the gap between the rocks originally didn't past fully through on some edges (mainly on the right side)
    I used the inverse eraser to make them past through (A)
    Also there maybe are a few artifacts around the edge to inverse erase (B)
    edited April 2017
    I found the rock pattern you traced in
    Trace the image in and create a rectangle
    Select the pattern and rectangle then press S to stack
    Do a join
