Clearest Glue for Transparencies?
jschmidtjschmidt Member Posts: 61
I print and cut transparencies to glue on a foil type of material - the glue I use is elmer's spray glue.  It does fairly well as far as being transparent goes, but you can still see glue specs between the transparency and the foil.  Does anyone have any suggestions to make the glue invisible?
