KNK zing loosing force
HairacHairac Member Posts: 44
Hi!
Recently I had the need to cut a material that I do not cut very often, I have a preset saved for it but now the cutting force required is magically jumped from 70 to 135, last cut at 70 was made in August. The mat is freshly renewed and I changed the blade a week before the cut.
Also when I use low force the hand with the blade doesn't go down at all.
There is a way I can fix this or I can just wait the moment when it will die definitely?
Thank you in advance!
p.s. I'm from italy and warranty just ran out so I cannot ship it to lab to make it fix :/
