Make the cut using the knife cutting point.
Make the cut using the knife cutting why does the image not cut in the same direction as shown on screen.
Best Answer
    I'm thinking the gurus will need more information - what cutter are you using, PC or Mac etc.
    edited February 2017
    I wondering it you have you mat set to landscape but are position the material you cutting in portrait or vice versa
    The ZIng user manual explains this on page 31 in the PDF version
    KNK Zing and Zing Air User Manual Chapters 1, 2, 9 and 10 are specific to the KNK Zing and Zing Air. Chapters 3 – 8 are Make The Cut only and will be useful to all owners of Make The Cut software. iloveknk.com/support/user-manuals/zing-user-manuals/
    if you have another KNK machine there are user manuals the cover them as well you can drill down from this page http://www.iloveknk.com/support/
    If that's not the issue your having
    I think we may need to know what machine your cutting with as the cut setup screens can differ for each cutter
    and a bit more explanation on what is happening
  • RepunzelRepunzel Member Posts: 3
    I am a mac user and I have the ink zing.
    Ok i have a zing but use windows
    Not sure if I understand what your explaining
    as an example do you mean your screen looks like this
    but the machine cuts this
    It doesn't matter if you are a pc or mac user - the setup for the virtual mat is the same. The virtual mat will default to landscape if you never changed it from when you first  set up MTC and will thus cut like Crazy Mr Zing's example above. You set your blade point to the bottom right of where you want to start your cut (and it will start cutting corresponding to the size of the bounding box of the shape you are cutting.
    There is an arrow on the virtual mat and if it is going to the left then you are still in landscape, but if it is going up on top, then you have changed it to cut in portrait. To print, you will have to change your printer's orientation at the print properties window and it doesn't have to be the same as how you cut.  I am dimensionally challenged, so for years with my zing I have my printer set to portrait and my virtual mat set to landscape.
    edited April 2017
    Repunzel said:
    Thank you
    i have another question.
    When using the print and cut my cut out is always out , does this mean mt zing needs to be calibrated?
    Have you ever performed a print and calibration on your zing ?
    as every printer is different the user has to calibrate the zing to their own printer
    Maybe I'm misreading your question but it gave me the impression that your thinking you need to have you machine calbrated by KNK ?
    Were as you do the print and cut calibration yourself as described in the manual
