Wondering About the Cricut....
I see Make the Cut is not supporting the Cricut's anymore?  Just wondering as I just got the new Explore Air 2 and wanted to do Rhinestone Templates and can not find any software to help me out.  Can I still use this software for that on my Cricut?  Or no......
  • Crazy_Mr_ZingCrazy_Mr_Zing Member Posts: 3,127
    edited February 2017
    The latest and only legally available version of make the cut does not support cutting to any circuit machine.
    I don't think those old versions that did support cutting to the Cricut will even support direct cutting to some of the newer Cricut models
    If the Cricut software you're using allows importing of SVG files you might be able to design your rhinestone pattern in make the cut > export as svg > import to your Cricut software
    @Snowland - Make The Cut! has not supported Cricut cutters for 4 years now. Any version of MTC that did support a Cricut will definitely not support any of the new Cricuts. It only ever supported the Expression and anything that was available up to the release of the Expression. Use the cloud software that you get free with the cutter you have, or use the latest version of MTC to design what you want, export to svg and then import to the cloud software supported by your cutter.
  • SnowlandSnowland Member Posts: 2
    thanks so much, I kinda figured that, but was hoping....  Wish I would have researched a bit more before I bought the Cricut.
    @Snowland - I agree, you should have done a better job at researching cutter and your software options =). One of the reasons MTC exists is because of the limitations of the Cricut family of cutters.
  • PennyPenny Member Posts: 2,076
    @Snowland ; You can make your files in MTC --> Save as SVG --> upload into Cricut Design Space.
    @Snowland - In my opinion Cricut is the best cutter machine ever. I tried some cutters and I found in Cricut the best combination: solid structure, accurate cut, easy to use and very affordable so don’t punish yourself for purchasing a Cricut machine but been forced to use "their" horrible software is a high price to pay, if you love freedom to create like we do. The suggestion from others members here is a brilliant idea. Use it so you don’t need to give up on your Cricut!
