Make the cut for mac
thiarathiara Member Posts: 1
on a mac: where is the folder to add the cricut plugin?
also is there a link to older versions of MTC 3.2.1 for mac?
    edited February 2017
    Quite a while back Support for Cricut machine was removed due to legal action from the makers of Cricut
    Therefore there is no legal way of obtaining that older versions the did support the Cricut
    I think the Mac version of MTC only ever supported the KNK Machines
    First, there is no folder on the Mac version of MTC because there was never a Mac version that worked with the Cricut cutters.  The Mac version was released well after Cricut support was removed from MTC and, as Crazy_Mr_Zing already noted, the Mac version of MTC only works with a KNK cutter (or a cutter like the Black Cat or Silver Bullet that can use the KNK cutter's plugin.)
    Second, there are no older links to any version of MTC prior to the version that is now on the home site to be downloaded. You would have had to already owned and backed up for your own use any older versions of MTC - if you didn't buy it and have it, you can't get it now. Provocraft sued MTC, not once but at least twice to ensure that you could no longer obtain a legal copy of MTC that would work with their cutters.
