How Do I Clear up a Blurry Textured Fill?
CocoPalmCocoPalm Member Posts: 7
So I looked in the discussions section and found the answer as to how to fill a shape with a pattern, but the discussion is closed. I have figured out how to do this, but the problem is, the pattern is blurry and I do not know how to clear it up. Can someone please tell me how to do this? What is causing it to be blurry? Thank you.
  • Crazy_Mr_ZingCrazy_Mr_Zing Member Posts: 3,127
    edited February 2017
    to conserve resources mtc down samples images
    also if you have your mat set to anything other than contrast eg green your textures will have sort foggy look in the mat color set
    to check if any on these are the cause to the blurry look do a print preview that will show what you project will look like when printed out
    if not
    can you paste the link the the discussion your referring to then we can understand just what your wanting to do
