tracing a photo
I found an excellent video that Sandy M made all about manual tracing.
I cannot get my photo suitably imported so that I can work on it. Old posts indicated that an actual photo could not be imported as a photo, has this changed?  I see that it can be done in inkscape,,, I like MTC and do not want to learn another program!
David
    What file type is the photo
    If you just want to bring the photo in in full try this
    in pixiel trace using the pixel mode set the threshold to 255
    it also helps if you can reduce the photo to a more manageable size
    as there no point importing a huge photo from a camera to print and cut it at 5 x 7"
  • SawdustSawdust Member Posts: 304
    edited February 2017
    I will give it a try thank you!
    @Crazy_Mr_Zing  Look at that! Brilliant.
    A whole new adventure, I am making sandblast masks. The husband of a workmate is a  war medal collector, he asked if I could recreate one of his medals. I am going to give it a shot.
    Thank you.
    dc
    do you know what war medal it is
    there might be a public domain image either svg or png
    @Sawdust, this may not apply in this case since the photo is of a medal and not a person, but Andy covered using the Color Scans feature in the March 26, 2013 webinar.  For those who have been struggling with making a cuttable image from a photograph of a person, this is a very helpful feature.  He mentioned it here:
    http://forum.make-the-cut.com/discussion/31660/make-the-cut-version-4-6-1/p1
    Scroll down until you see the section title; Gray Scale "Color Scan" Trace Option
    And the Vimeo showing him demonstrating this technique (starting right around 51:20 into the webinar) is here:
    @gabe @Crazy_Mr_Zing Thank you for the choices! I have tried them both,,,, Not there yet. Would either of you be willing to give it a go? I tried the manual trace which is awesome but I do not have enought skill for this one. I think there needs to be some artistic discretion involved, I have none. The greyscale I just cannot make it work, Andy makes it look so easy. If someone is willing I would pm you the photo that I have.
    In the end this will end up sandblasted onto a piece of marble and stained.
    David
    I'll have a go if you send the file
    do you know the name of the medal
    MTC imports whole photos just fine for me. To add you might want to set your virtual mat to contrast. Also You need to click on textureize path while going up to 255 on the threshold. At 255 blackout can be checked but really unnecessary. If you don't click on texturize path then all you get is a solid black square shape. Sometimes if I do not want to hand trace, then I edit my photos in a photo editing program in order to remove the background. Then it is very quick to do a good single color trace as long as the photo is large enough. Small thumbnail sized photos are not really good for tracing - not enough pixels even if you resize them larger - they are too grainy.
