Can't view the screen in Windows 10
I have a Zing (2011) and haven't used MTC for quite a while because I can't get MTC to work properly with Windows 10.  I had purchased a computer  - late 2015.  I can not view the menu bars especially where I add a string of characters. I really want to use this machine.  Can someone please tell me how to fix this?    i posted a question here last year but rec'd no answer.  I was hoping MTC would have an update by now. I've tried changing appearance and icon sizes in the settings menu. I'm not very computer literate and don't understand all the lingo, but there has to be a fairly easy fix.  If it can't be fixed I have a barely used Zing for sale.
Thanks for any help you can give.
Cricut Expression 2008 & Proud owner of a KNK Zing 2011
    edited February 2017
    I think the ease resolution is dependant on you hardware and version of windows 10
    It's disappointing the someone at make the cut hasn't offered something in the way of a workaround document maybe its not so easy
    if the icons or tool bars are distorted or blurry then this probably won't work
    if the are just too small to see
    You can try this
    Click
    start > settings > system > display >
    If you have a screen like this slide the scaling slider (red arrowed)  to the right a little
    not too much maybe try 125%
    now start up MTC see if there is  an improvement
    you can take this further though is seems to be a little more technical
    This blog seems offer a explanation
    http://news.kynosarges.org/2015/09/05/dpi-settings-in-windows-10/
  • scrappinmelscrappinmel Member Posts: 24
    I've tried both suggestions from Crazy_Mr_Zing and tuicarlos and neither have helped.  I tried to change the display settings and that didn't work.  I even adjusted the dpi and no help.  It actually made it worse.
    I reset the interface and that made it much worse.  Attached are some screen shots. The bottom pic is before I changed anything.  The other two are the changes I'd made. Thanks so much for trying to help me out!
    What screen resolution at you running on
     Click Start > Settings > System > Display > click advanced display settings
    what the setting in Resolution ? and what options are there for setting it lower ?
    The only other method I've read of is creating a manifest file
    Creating manifest file fwas suggested in this discussion but I don't recall anyone ever saying they tried it or were were successful in resolving the issue with MTC and super Hi Res/dpi
    This information came for here as a resolution for the same issue with adobe app's
    I have altered the text as it would applies to MTC
    although they claim this is easy messing with the registry can cause issues should you make and error
    They suggest they backup you registry before you begin and know how to restore it if something goes wrong
    Root of the problem: Short answer: Adobe. Long answer: When the apps load, Windows asks if the app is High DPI aware and these apps answer “yes”. Which is why you end up with an interface for ants.
    The solution: Have the app tell Windows that it is not DPI aware and let it scale everything properly. (Granted, this is not the ideal solution, but it does make the apps usable again)
    How it is done:
    1. Tell Windows to look for an external manifest file.
    2. Create the external manifest files.
    Step 1: Tell windows to prefer an external manifest file
    As always, make sure you backup your registry and tread lightly in this area. We are just going to add one line. This is VERY simple. Do not be intimidated.
    1] Press Windows Button + R, type “regedit”, and then click OK.
    Navigate to the following registry subkey:
     HKEY_LOCAL_MACHINE > SOFTWARE > Microsoft > Windows > CurrentVersion > SideBySide
    2] Right-click, select NEW > DWORD (32 bit) Value
    3] Type PreferExternalManifest, and then press
    4] ENTER. Right-click PreferExternalManifest, and then click
    5] Modify. Enter Value Data 1 and select Decimal. Click OK. Exit Registry Editor.
    Step 2: Create and place the external manifest files
    Now comes the fun part.  You will just have to copy your manifest file to all of the application folders that you would like to change the scaling on. For example, MTC!.exe is located at: C:\Program Files\Make The Cut!\MTC!.exe and I created a manifest file in notepad or a text editor named MTC!.exe.manifest to place in that folder.
    Sorry I haven't responded, busy week. Thank you for your suggestions....I hope to try them this weekend. I will post back. Though I did try to change the resolution several times with no changes that work. Will post as soon as I know.
    Unfortunately I was unable to get it to work on Windows 10.  I give up.  I've sold my Zing.
    edited March 2017
    Did You realise that the manufacturer of your Zing, KNK USA is not the same company that produces Make the Cut which is Make the Cut LLC
    Its a little disappointing that Make the Cut support appears to have not paid much interest to this issue as high resolution display are becoming more and more common therefore this issue will effect more and more users
    Another option would have been to purchase Sure Cut A Lot (SCAL) though I'm not 100% sure I don't think it has the same issues with high resolution displays
    SCAL . I guess downloading the Trial Version would confirm this
