PNC with Contour Shadow [Resolved]
sdken1sdken1 Member Posts: 32
edited February 2017 in Resolved Issues
I am trying to PNC a rainbow.  I want to do a shadow the exact size or a little smaller so that when I cut it, it cuts it solid.  My problem is when I do the shadow with the blackout checked this is what I get.  What would be the easiest way to make this solid?   I am sure it is not nearly as hard as I am trying to make it. :) I am using a Zing but I don't know if that matters.
  • sdken1sdken1 Member Posts: 32
    Not sure if I did it the easiest way or not but I figured it out.  I used the freehand line tool and used the closed in the both sides of the bottom of the rainbow.  Selected it and welded it, broke it apart and got rid of all the extras.  Worked perfect. :)
