Zing Air won't work!
hobbeshobbes Member Posts: 4
Hi--
When I try to cut with my zing everything goes fine until I hit the cut project button.  Then the knife moves back to its starting point (from where I set it with knife point) and it pushes the material I am cutting through the zing bed.
It did that a few times and then it just stopped moving the knife at all when I try to set it with knife point.
Any ideas?  Thank you.
    edited January 2017
    Ok sound like something possibly beyond me but lets just confirm what is happening
    -The cut with box pops up
    -You select knife point as cutting mode
    -You click on set blade origin and move the blade to the desired start position,   with the arrows and click finished
    > I believe when you set the origin you must move blade to the left even if its just a small distance if not it can cause a issue sometimes.
    -Then you click cut project
    ...Then the zing moves the blade to the far right and rolls the mat through
    Have you tried a different file
    As this is your first message I'm assuming you are a new user do you have the Zing / Make the Cut user manual available here http://www.iloveknk.com/support/zing/
    sometimes it helps us help you if you attach your file using the button on the message tool bar circled here
    @hobbes - Are you on a Mac or a PC?
  • hobbeshobbes Member Posts: 4
    That is exactly correct Crazy.  I am on a pc.  I have been using the zing for a year or so with no problems.  then all of a sudden this happened.  I am not sure what you mean about the message bar...
    oh.  I understand the file.  I did not try a different one actually.  I will do that.  thanks.
    edited January 2017
    I suspect this is an issue beyond my knowledge the more information you can provide will help others determine the issue
    Does it happen with other files ?
    Does the box appear with the progress bar indicating the data being sent to the zing ? and progress to finished even though the zing has stopped
    Are you using MAC or Windows?
    What connection USB or Bluetooth?
    Is the file large ,highly detailed or both ? This is where it helps if you can provide the file if you which to keep it private you could send it to @SandyMcC via private message
    I mentioned the message tool bar in relation to attaching your file to the forum so other can see
    the button indicated in this image is a way of doing that
    well what do you know.  another file worked fine!  Strange because I have used the other one numerous times before.  Thank you for your help.  I will see if I can figure out what is wrong with the one that is not working.
    @hobbes - going to suggest there is something astray on your mat way over to the right for the file that gave you problems. CTRL+A to select all, and see where the bounding box goes. Let us know.
    It could also be one of the bugs related to setting the origin.  If you try the file again, avoid using the up/down arrows too much in the set origin window.  For example, try to have the mat already positioned with most of it behind the Zing Air instead of using the buttons to move it into that position.
