Titan/Make the cut
I use to have Make the Cut running on my US Cutter Mh series cutter and I bought a new Titan.  Can I use Make The Cut on my Titan?  Thanks.  I am using Vinyl Master at the moment and I hate it.
    The answer is on the page where you download plug ins for supported cutters.
    http://www.make-the-cut.com/Download.aspx?ref=lp
    If your cutter isn't listed, then it is not supported.  But if Vinyl Master can import an SVG file you could still use MTC to design.  You would export the final design as an SVG and then import it into VM.
    Vinyl Master Cut lists the ability to import/export svg files so Gabe's suggestion will be a workaround for you.
    USCutter should provide support for you if you are having problems with VMCut.  There is a good bunch of folks at the USCutter forum which would be the best place for support and help from fellow users.  http://forum.uscutter.com/
    Learning new software is a real pain - I have used VinylMaster for years but I am still using version 3 but I may be able to help and will try if you ask.
    Welcome to the forum
