New to Silhouette Studio Basics -HELP!
sip2604sip2604 Member Posts: 4
I recently purchased a Cameo 3 and have been using the Silhouette Studio Basics.  I am attempting to use the knife tool to cut an image in different parts.  After making the cut I see where the white line is for the cut, but I'm unable to separate the part of the image that I cut off.  Am I doing something wrong?
    edited January 2017
    Are you cutting completely though from outside one side to the outside of the other side
    I don't think you can link multiple cut together if you was to say cut a right angle you would need to change select poly in the knife tools options and perforn the cut in one action
  • sip2604sip2604 Member Posts: 4
    yes I am cutting completely through from one side to the other. It leaves the white line as if it made the cut but when I try to drag the cut piece away it doesn't detach and drags the entire image.
    I'd check what cut line is set in the program if I were you - If I'm right there's one that leaves bit attached for selling as decoupage!!
  • MeFlickMeFlick Member Posts: 9,073
    edited January 2017
    sip2604 said:
    I recently purchased a Cameo 3 and have been using the Silhouette Studio Basics. . . .
    Welcome to the Make the Cut software support forum. Just to clarify - it looks like you are not using Make the Cut software program with your cutter so the knife tool you are referring to is the one in the free Silhouette Studio software program that comes with the cutter is that correct? If that is the case, you might be better helped finding a help or support group dedicated to the Silhouette Cutters and their software programs. There are some Facebook groups I believe if you do Facebook. The one user support forum that I am aware of is found here:http://s15.zetaboards.com/Silhouette_Plus/index/ You can find the FAQ section of Silhouette's site found here: https://www.silhouetteamerica.com/faq
    Also found this article on using the knife tool in the silhouette program on the Silhouette blog: http://blog.silhouetteamerica.com/2016/09/customize-ready-made-designs-using-the-knife-tool?paged=0
    (There may be more - just enter knife tool in their search box on the forum, this one and several more were shown in the results.  Only quickly looked at this one.)
    Thank you. Yes the knife tool I am referring to is for the free basic software that comes with the cameo 3. I have not upgraded yet to the designer version as I am seeing how it goes first. Sorry I'm new to the crafting and Silhouette world. Lol. This may seem like a silly question but is Make the Cut a different software than the one that comes with the silhouette? Thank you for all of your help and for the links. I'll make sure to check them out.
    sip2604 said:
    . . .  This may seem like a silly question but is Make the Cut a different software than the one that comes with the silhouette?  . . .
    Yes, Make the Cut is a 3rd party software program that was written several years ago.  It works with a variety of different cutter brands including the original Silhouette cutters and the original Cameos.  I gather it will cut to the Cameo 3 but will not work with the print and cut feature to that cutter.  There are also other 3rd party software programs besides MTC which can work with a Cameo cutter so be sure to check them out before committing to their Designer program.  There are pros and cons to all sides so educate yourself and understand them all before you decide on additional program(s).  Especially if you don't want to be locked into the silhouette file format and have the potential to upgrade later to another cutter.
