  • Crazy_Mr_ZingCrazy_Mr_Zing Member Posts: 2,389
    edited January 3
    Ok I've not done this before but here a webinar video
    Make The Cut! and Popup Card Studio Q&A Webinar - December 09, 2014
    01:52:13 MTC: Bryan returns to Julie’s question regarding creating weeding lines
    they was discussion of doing a better tutorial video but I've not found that yet
    Now that I worked it thought it not to tricky well not when someone shows you
    it basically change the weeding line to rectangle remove the text from those rectangle by boolean joining then converting what remains of those rectangles to single line using thin paths
    My example Text of and rectangle background
    Create a copy of each and hide the originals
    Use the pencil tool create a line over lapping background (copies)
    hold ctrl to keep it straight
    Duplicate the line to create suitably spaced weeding line
    with all these lines create a tiny shadow I use 0.01mm
    I also unchecked auto simply output
    Discard the original lines
    Select the line-shadows and the background do boolean join intersect
    to crop the line-shadows to the background
    Select Text and the line-shadows do boolean joint difference
    Select the line-shadows and use thin paths to convert them back to single lines
    Make the hidden original text and background visible
  • ahuntingahunting Member Posts: 635
    Holy Cow!!  I thought it would be easy.....  : (  Anyway, Thanks @Crazy_Mr_Zing !
    edited January 4
    I didn't think it being too difficult , a little tricky maybe
    maybe its the way I explained it
    Thinking about it further maybe I could have made it simpler
    as cropping the line to fit the background is not necessary if you don't a little extra vinyl waste as the cut line may extend outside the background if you
  • Liz_ALiz_A Member Posts: 9,092
    @ahunting - it's only hard the first time around. Some people create the lines and save them as a shape in their own Basic Shapes category, then the file is there for when they need it.
