Looking to upgrade from my gazelle, to something with a bigger cutting size, any recommendations? Likes or dislikes? Not looking to spend a ton. I've seen sign wearhouse and us cutter have some that cut over 30 inches, not sure if they will work w mtc
Gazelle owner
0 ·
Pazzles Vue also the easiest machine in my collection to use, and it does a great job cutting accurately around printed images.
US Cutter machines are fine if you are mostly cutting vinyl and don't need the extra pressure for cutting heavy cardstock and other media. You probably won't be happy with any of the low cost cutters, as none of them cut with as much pressure as the Gazzelle that you already have.
Let us know what you like to cut most, and it will be easier to answer your question more specifically.
