Layer order in Make the Cut which reflects the order the cuts should cut
I created a right and left bottom for a 18 inch doll shoe.  My new cutter ArtisticEdge is not supported my Make the Cut so I am having to export as a SVG the problem I am having is when I send it there the cutter is cutting all over the place.  I can change the sequence of the cuts in Artistic Simple Cut 7.1  but it is not holding the settings.   I looked at the layers in Make the Cut and the order is all over the place.  For the life of me I can not remember how to change the layers in Make the cut to cut each shoe in the order it should be without cutting over the top of the other one.  Is there a place I can find how to change the layer order to reflect the correct way the shoes should cut when I bring it into the Simple cut 7.1 software.
    edited December 2016
    I not really understanding what you meaning
    It might help Us understand if you can attach you MTC file
    You can change the order of layer by using the up and down arrow buttons on the layer menu
    although I'm unsure if that changes the order the shapes are cut in MTC as I think it automatically calculates the best cutting path
    If you have each layer separated then to re-order them use the arrows to up or drop them in the list.  That way you can sequence them in the order you want them to cut and then export as an svg.  Presuming your software imports the svg in the format that MTC exports it you should end up with all your layers in the same order or upside down which means you would need to reverse them in MTC before exporting.  Best of luck.  This is just an expansion on what Crazy_Mr_Zing suggested.
  • SandyMcCSandyMcC Member Posts: 7,502
    The layers do not necessarily cut in the order they appear unless the software by Artistic Edge is designed to cut them that way.  You would need to find out how to control the cut order in that program in order change it.
    @Di-Lite's explaination is for a different program, not MTC and not whatever the Edge is using.
