weeding tool
Hi all:
This is my first post.
 I have a Graphtec CE6000-40 and have been cutting some pretty small decals...have found a couple of things that have helped quite a bit.  I use high tack clear premask.  I weed the easy stuff the regular way...then I apply the premask, flip it over and use a needle to pick out the tricky stuff. Use small clamps to hold it tight on a suitable sized piece of foamcore. Kept losing the needle but after inserting it into an Xacto knife handle...no probs, and it has worked out to be a great little tool (Also use a sharpening stone to keep the point sharp)
