Rhinestone fill pattern question
miresthimiresthi Member Posts: 6
Hello All,
I'm new to posting here, but have had MTC for a few years, along with a KnK Zing.  I'm new to using both (MTC and Zing) because I didn't have time to play with them until recently.  Now I'm trying to do Rhinestone templates and I am wondering if there's a way to change the fill path on the Rhinestone feature, or a way to work around it.  As it is, when you choose to fill the object with "rhinestones" (circles for the cutter), you get the fill arranged in straight horizontal lines.  I have an object with lots of curves and I am trying to figure out how to set the fills up to follow the curves, without having to add in each and every single stone manually.  Any suggestions or advice?
Thanks so much.
Best Answer
