Modified Slice Form Bird
CharoCharo Member Posts: 678
edited September 2016 in Your Masterpieces
I found a similar bird on the web somewhere and my attempt ended  up as a modified slice form.  Made a mistake by starting out too big:  slice forms don't reduce well at all!   I had hoped the 150% reduction in attached file might fit in a card (tabs would need to be added) but it is very very difficult to put together now.  However I was quite pleased to discover the large version would stand on it's own.  Birds are held together with a dot of glue at beak, top of head, and back.  Bird on slice form base is supported with a double layer of paper glued inside tree trunk.
