Greetings! I have a new ASC 365 vinyl Plotter cutter
@Rizzy_3 - well cutters don't actually print, you need a regular printer for that, and its File => Print and choose your printer from the list.
Your cutter is not one of the supported cutters, but if it supports HPGL, then you can possibly send a cut to the cutter using the Print command. To do that:
File => Print Options => check Print Wireframe only, set options Then File => Print => choose your cutter from list
Hi Rizzy_3 and welcome to the Make the Cut! software support forum. It is not a generic forum, but one specifically for users of the Make the Cut! software program. Since you just joined the forum and indicate you have a new cutter that is not one of the supported cutters of MTC but note that you are "looking to get using this vinyl cutter, however I am not sure how to use the software." I am assuming that you are referring to the software that you got with your machine rather than MTC. If that is the case, your best bet is to look for help and support from the people you obtained that specific cutter from if that is also who provided you with the software.
You can download a free trial version of MTC to try it with your cutter if it supports HPGL as Liz noted above. To find a trial of MTC, you would go to their site here: http://www.make-the-cut.com
Good luck, let us know how that goes for you.
