[Tutorial] Make a butterfly popup card
ThecuttingartThecuttingart Member Posts: 25
edited January 2016 in Tutorials
Hi all,
Today, I’ll show you easy way to make a butterfly popup card. I made this pop up card last year. I hope you will like it.
You can watch tutorial in this video to
PREPARE: First, we have to prepare some material to do this card.
– Cutting knife or hobby, craft kinife.
– Cutting mat (or wood/glass/ceramic board)
– Pencil
– Erase
– Color paper
Now, we start to work
– Step 1: Fold paper and draw a half of butterfly on it
– Step 2: Cutting outline pattern you’ve just drawn
– Step 3: Repeat steps above with other color paper, and with other butterflies size
– Step 4: Make some rectangle tubes.
Cutting paper to rectangle shape, and then you roll them to rectangle tubes in the same size.
– Step 5: Put tubes on background layer card, and glue them as this
– Step 6 : Glue butterflies together, and then glue them on tubes, you can also put some tubes between butterflies
Now, you have a popup card with 3D butterflies :)
You may be dowload pattern at https://drive.google.com/file/d/0B67dWMjvv-5WUzNuVk14SUUzenM/view
Thanks you for follow.
Post edited by Thecuttingart on
  • 1cardcreator1cardcreator Member Posts: 844
    edited January 2016
    @Thecuttingart it's amazing what you can cut without a machine. Beautiful card, thanks for sharing. ~ Diane
  • Liz_ALiz_A Member Posts: 10,249
    @1cardcreator - lol I couldn't cut like that, and is the reason I have a machine, ha ha!!
  • GabeGabe Moderator Posts: 4,543
    @Liz_A, coming from the glass etching world of the 70's, I did a bunch of cutting by hand with Xacto knives. I must have had 7 different kinds of knives. I didn't even know there was such a thing as a cutting machine. Can you say "tedious?" When I saw the Cricut, I immediately wanted one, just to cut my etching stencils. But then I learned that it used artwork from cartridges and was limited in what you could cut. Decided against it and started trying to find a different cutter, but they were so darn expensive. It took me until 2010 (or was it 2011?) to finally buy a cutter - my Zing. And I just got a new air compressor and other stuff needed to get back into glass etching. I may be slow, but I'm getting there. :)
    @Liz_A, @Gabe, I couldn't do the exacto knife cutting, I'm amazed you could Gabe. I bought my Zing because I was tired of cutting out the outside perimeter of the items I used to put in my pop up cards. I still need to figure that out! I hope to learn it by the end of the month but I keep running into dumb obstacles that have nothing to do with print and cut! Like my computer not recognizing my Zing as a cutter or my dyslexic inability to figure out what "portrait" means, lol. I've been cutting with no problems for 2 years, and now I see all this time I thought I was working in portrait, I wasn't, because I was setting the layout to portrait and placing my 8.5x11 paper on the mat in landscape! I think I had such a hard time in the beginning pencil tracing on the mat (because of the dyslexia) that I ended up using the old cricut/ scal set up. Who knows if I was doing that one right either, lol! Now to learn how and what to import and cut. I'm sometimes amazed I find my way to the coffee maker in the morning, ha ha! Off to search more videos, lol. ~Diane
    Thank you that's beautiful
    @Gabe, @Liz_A @1cardcreator I got a cutter because I could not even use scissors to cut - a roller blade cutter solved my straight line cuts - but a Robo gave me my first ability to cut curves. I'm lethal with a scalpel and get the shakes when I slash a finger. Now I think of nothing of cutting fine outlined work.
    What these guys do is pure magic.
  • ThecuttingartThecuttingart Member Posts: 25
    With me, a cutting machine is similar a printer, they print every thing we draw or paint in graphic software.
    I have more than one Zing laser machine, but I only use them for paper, not for other material.
    If you work with glass or hard materials, you can try a CNC machine instead a laser machine. Because low price for CNC blade (compare to laser discharge tube), they also engrave more deep than laser machine.
    On a base, both CNC and laser machine cut outline with vector file ( you can creat with a vector graphic as Illustrator, coreldraw, inkscape... - You can try inkscape, it free and powerful) . And they engrave with bitmap or 3D file.
    Some of free graphic software you can try:
    - 2D bitmap: GIMP, krita : you can use them to creat picture for engrave.
    - 2D vector: inkscape: make vector files for cutting outline
    - 3D: sculptris, blender, sketchup free.
    All of them are free, so you can try them for your work.
    You can see a work I do with 15mm wood
    Oh wow - that's so beautiful and intricate - 'right up my street' - (what I like). I'm hoping when I get the Force I will be able to turn my files into works of art like that if I can get to grips with operating it. It's so impressive. Thank you for the information, many on this forum will appreciate it.
    @Thecuttingart when we write about the "zing", it is not a laser cutter, but a drag blade cutter.
  • yupyup Member Posts: 341
    Very nice. Thank you for sharing!
    Oh, I have some Zing lasers of Epilog, USA :D So I thought u have it,too.
  • pixelpusherpatpixelpusherpat Member Posts: 305
    Your creation is very stunning. So wonderfully intricate! I can hi-speed drill hand engrave like that, over a pattern stuck to my substrate, but have nothing to match cutting in 3D! Gorgeous! Pat in Kent (USA)
    @Gabe - my experience is similar to yours. I have an Olfa artist blade I got a lot of years ago somewhere in the US when I used to travel for my job. I used that for exact cutting, along with a steel ruler with a cork backing. Tedious yes, and one reason why I never cut a lot of the same, mind boggling boring too. I walked into Michaels one day and they were featuring the Circut...walked out with one, after I saw the USB port, oh goody, I can connect it to my computer. Disappointing, computer could have cared less about it. Sat for awhile before I found the software that started the revolution.
  • NancNanc Member Posts: 632
    Love the layers!
