New features for MTC
sderamonsderamon Member Posts: 3
Hi,
I'm using MTC for more than 2 years. I'm waitting for two inportant improvements but is not implemented yet.
- Possibility to work in mm. Not only introducing values with a mm at the end of the input size
- Possibility to select the cutting order like in others softwares. It's important for don't move a lot the paper in the machine (p.e.don't cut in the top, then move to the bottom and then move again to the top)
Some one knows if it will be available in the future?
Is possible to connect the KNK with another software?
I want to buy a new die machine and this is important to take the decision
Thank You
