Paper embossing success
JensMomJensMom Posts: 1,145
edited February 2015 in Tips and Tricks
I had an awful time trying to figure out how to emboss paper using my Cougar. If I used the mat I bought for that purpose , it made marks with the pinch wheels because it was so thick, so I started using different things under the paper to give it a "cushion" so it would emboss and not leave the grooves in the paper. I had a piece of fun foam, the type you by at Michaels and viola, it worked perfectly. I was able to emboss snow flakes on my paper and they look great No water needed on the paper as well. I used MTC file and the embossing tool, and made 2 passes on pressure 100. Just wanted to share with you all and hope it works for you.
Post edited by JensMom on
